DayTripping
Thanks. I am open to all ideas. Brainstorming is almost always an advantage. I like the Weistec option but I just dont' think it is worth almost $400 to me. I just don't see the value at this point. My mind may change later and the 10% discount wasn't enough to make me impulse buy them anyway.Or a piece of thick flat (or angle) metal, aluminum or steel, with holes or a slot.
One thing looks certain - J-bolts or U-bolts will be a bit more fiddly when attempting to set it on. Might need additional hands. The Weistec adapters would allow setting it onto the rails, and then adjusting until the holes match up.
While the J-bolts might be a bit more fiddly (I do have a helper), it can also allow for easier adjustment after the fact if needed.
My initial plan is to build it as is and set everything up like it should be from the factory, but without sealing it down. I am going to look at how it fits and mark where it sits on the bed rails and tailgate. I'll do some shakedown runs to make sure everything is good.
Then I will go back and redo each corner with the alternative mounting system once I am satisfied with the solution.
