Rivian_Hugh_III
- Thread starter
- #1
I'm curious why EV's have evolved to require a hand-held attachment for charging. This made sense for gasoline, but it doesn't make sense for EV's IMHO.
It seems to me an under-vehicle automatic charging device would be much more convenient. You would plug it in and then lay it on the ground. You would simply drive your vehicle over the charging pad, stop the vehicle and then walk away. Perhaps it would take over steering for the last 5 feet so that the vehicle is perfectly aligned over the charing pad.
Then something from the vehicle would drop down to physically connect with the charging pad, or something from the charging pad would rise up and fit into a port on the belly of the vehicle. Electrons would be exchanged.
This would have so many advantages.
Primary among them, you wouldn't have to manually attach the charging cable and unattach it literally every time you drive. To me (sans EV) that sounds like having to filly my car with gas every time I park it in the drive way. What a hassle.
Presumably there's a whole host of reasons why this is a terrible idea, because it's so obvious it must have been considered and discarded. But what else might be a better way to charge EV's? Close-range inductive? Other?
I don't believe we'll be charging our EV's by hand for the next century. Someone will make this a lot more convenient at some point. Maybe Apple. When that time comes, I hope I can retrofit my Rivian.
