Rivianmd
- Thread starter
- #1
Starting a thread to discuss specs around the 2170 cells and overall pack capacity. I am fascinated with the tech side and specifically the cell chemistry and the wh per cell. I am also intrigued with the change in language using “large” pack vs. actual kwh capacity. Recently we’ve received information that the pack will be somewhat less than 135 kwh. This concerns me because there are no 2170 cells in mass use today that have the wh capacity @ 7777 cells for the large pack which would allow for a proper buffer at 135 kwh. So either Rivian has developed a proprietary cell with LG Chem that outperforms all other commercially available cells today, or the average wh per mile has dropped significantly from ~ 425 which has been the running assumption. (Or maybe they’ve upped the cell count?) I remember a tweet from RJ stating that they got 318+ out of a 135kw pack on the long way up. Maybe we are underestimating the vehicle efficiency? Also, if the are marketing the vehicles at 300+, my assumption is that the vehicle new will exceed that threshold for all wheel/tire combinations. I can’t imagine they would have the 20’s for instance come in less than 300. I also hope that they are engineering with a significant buffer so they can offset degradation. Again, all pointing back to wh’s per cell. Do others have thoughts on this or additional info to share?
