Khaneric
Simi Valley, CA
Besides the UFO noise pumped out when driving, I've heard two noises that the Rivian makes. One is the bird chirp when the vehicle locks. There is another noise too - it's hard to describe but sounds kind of like someone playing notes on a xylophone maybe... It happens at seemingly random times after I get out of the vehicle but am still close by (like getting ready to charge it in the garage for instance). Can anyone tell me what that noise means?
I've heard this as well, it's very random. I thought it was Wifi Connecting, bluetooth connecting, etc. Probably the key like others have said.
rockdogz
Southern CA
So itā€™s saying there is a key left inside? Because thereā€™s no key insideā€¦
Possibly is the disconnecting/reconnecting of a wireless signal as suggested
mabowden
Socal
Toby Flenderson
My apologies if this has already been asked. I did search the R1T owners guide but no dice yet.
Does the R1T have a maintenance schedule? I know it will be far less often than your typical ICE vehicle, but I'm sure certain things must be checked on a schedule?
crashmtb
Man oh Manitoba
Itā€™s pretty much brake fluid every couple of years. Drive unit oil is supposed to be changed at some high mileage level. Iā€™d rotate tires too.
mabowden
Socal
Toby Flenderson
Do you think tire rotations are necessary with quad-motor drive?
crashmtb
Man oh Manitoba
Yes. Same as on any other AWD vehicle. itā€™s not always putting the same amount of power(or weight) on each wheel. Plus with a spare, you can do a 5 tire rotation, and get 20% more tire life.
timesinks
R1T, ID.4, Sprinter
If it's the sound I think you're describing, it means "I didn't lock when you walked away."
For me, it usually means a door is ajar.
SeaGeo
Brice
Xc60 T8
A little bug I just noticed is that the Nav seems to think that there aren't chargers available along some routes, but if you search for a shorter distance along the same route it will find them. For example: Seattle to San Fran it doesn't recognize any chargers and says I'd run out of energy south of Portland. But if navigate to Salem, it finds and adds a chargers in Portland. It doesn't seem to be an issue with distance either, as it fails Seattle to Glacier, but works with Seattle to Boise.
Anyone else notice this? Software 2022.15.0.
mabowden
Socal
Toby Flenderson
Hmmm... Think i'm gonna just SEND IT! I really dislike tire rotations
crashmtb
Man oh Manitoba
It did this when I set the nav at first mile to go from Sonoma to Winnipeg.
šŸ¤—
crashmtb
Man oh Manitoba
I use them as an opportunity to get accumulated dirt out of the inside of the wheels. Gets bad with gravel roads.
SeaGeo
Brice
Xc60 T8
šŸ¤—
That's to be expected. Canada doesn't have electricity. ;)
crashmtb
Man oh Manitoba
Youā€™re thinking of Saskatchewan. Everywhere else does. šŸ˜¬
jjswan33
Joshua
Sandy, OR
Also if you use conserve. Iā€™m at nearly 5k miles and I am considering a rotation.
