Anyone figure out how to get ride of the crossbar whistle sound?
NashvilleR1S
Nashville
2023 R1S, 2022 Pilot
Cinematography
I love the look of the cargo crossbars, don't mind the negligible range hit, but the dang whistle sound is about to make me take them off for good. It's so high pitched at anything over 30 mph. Anyone figure out a good solve to this yet?
Byulasfjazz
Utah
Van
Franchise owner
I too posted this. I’m ordering a few rubber/ plastic strips to insert in the grooves. Let you know which fit and it it works.
FooF
FooF
Mountain View CA
2022 R1S Launch Green
If the little crossbar levers are sticking out too far they will whistle.
If you remove the rubber from the crossbar there are two adjustment allens
With the end of the crossbar facing you the right adjustment seems to set the play (clockwise tightens the play if crossbar feels sloppy when latched to the crossbar mount, counterclockwise to loosen.
After adjusting the play to remove slop the crossbar lever may be sticking out too far.
Turn the left allen with the latch closed and lever down but not attached to the roof and you should be able to adjust the lever so that it is no sticking out too far from the crossbar which should keep it out of the wind and stop the whistle.
CommodoreAmiga
So many people complaining about various noises from their trucks.
There are some obvious solutions out there - AC DC, Van Halen, Def Leppard!
If only the stereo was better. Mine isn’t, and it causes even more rattles.
lefkonj
Jeff
New Jersey
A7/Q3 R1S ordered
Same thing happened on my past Audis, was told 'This is expected and you aren't intended to drive around with them on with nothing on the cross bars'. Take them off easiest and best solution.
rodhx
Rod
Alabama
R1T, 03 IS300 5spd track/autox
Yep, wind noise is the universal constant with any rack. It's always there whether you notice it or not.
I do not notice any noise from my crossbars when on the bed but the prominent AT tire noise probably masks it anyway. Haven't put them on the roof yet.
Byulasfjazz
Utah
Van
Franchise owner
Here is the solution... cheap and quick and looks good
NashvilleR1S
NashvilleR1S
Nashville
Cinematography
Love this. Too bad I can't find it in stock anywhere. But if that's where the whistle is coming from I can figure something else out.
NormalLife
Michael
Austin, TX
Audi A6, Audi e-tron
Med Device
I found them on https://www.rerack.com for $10 per strip
Yakima JetStream Bottom Bar Infill, 70"WAR-2412
Never ordered from the site before, but apparently the order is on its way. The load bars are all I have of my Rivian so far, but better to be prepared!
NashvilleR1S
NashvilleR1S
Nashville
Cinematography
Can you link it? That site is insanely bad. Can't find it.
NormalLife
Michael
Austin, TX
Med Device
Sevn86
2018 Range Rover Sport HSE
I did the same. Rivian should be here this coming week but I ordered the strips from ReRack and it says out for delivery today. So I think it was a legit site.
