rancur
Will
Phoenix
www.willcurran.com
Entrepreneur
Hey yall!
Shout out to @WattTruckMatt for inspiring a lot of this and giving us so much helpful info.
Wanted to return the favor and make a video detailing the process for doing 12v on the R1T and installing a roof and bed rack.
?️ Products I Used:
Overland Ruff Rax - https://overlandruffrax.com
Rigid Adapt 40 with GPS - https://amzn.to/3tkN1k8
Garmin PowerSwitch - https://amzn.to/3TtCIEZ
12 Gauge Wire - https://amzn.to/41yc5kn
1/2 Inch Loom - https://amzn.to/3RuJWGn
7 Wire - https://amzn.to/48iLgTq
Crimping Tool - https://amzn.to/3RJende
Crimp wire connectors - https://amzn.to/3RLQyQX
Terminal connectors - https://amzn.to/3NqSVY0
Waterproof Box - https://amzn.to/3NvvJrt
Magnet Zip Tie Holders - https://amzn.to/3Tt7wWn
KC Wire Hider - https://amzn.to/48pC6op
1/2inch heat shrink - https://amzn.to/3Rprb79
Heat shrinker - https://amzn.to/3tmvwju
Wire inserter - https://amzn.to/47YTAIo
Scotch heavy duty fasteners - https://amzn.to/3v0Pxwp
Locktite - https://amzn.to/3TLfoTF
I made a complete list of all of the products and mods I’ve done so far at https://www.willcurran.com/rivian
WattTruckMatt
Austin
2022 Rivian R1T
Nice work (and thanks for the shoutout)!
I can't wait to get my Xtrusion Overland roof rack (once it's released). I'll be doing a similar wiring job down the windshield to run roof lights to the PowerSwitch.
I wish I had taken out the tub when doing the PowerSwitch install in the frunk. Would have made life easier. I've had it out for other stuff, it's not hard, just a handful of screws.
Trick to getting thicker wires through the grommet.... lube. Silicone spray works well but it's slow going to get it to slide through for sure.
I drilled a hole for my wiring in that small bed corner plastic piece. I have my light wires going through a grommet there. I've already purchased a new piece if and when I need to go back to stock. Wasn't too pricey, less than $100.
rancur
rancur
Will
Phoenix
www.willcurran.com
Entrepreneur
Oooh did you get the piece from Rivian? I might just drill then knowing that.
We tried the dishwasher soap but it was just too thick to make it through the small hole. That 7 wire was beeeeeeefy!
WattTruckMatt
Austin
2022 Rivian R1T
Yeah that grommet isn't super forgiving.
Yes, I picked up the part from the Service Center. Be careful when drilling. It is tight tolerances to find the gap between the bedside and the tonneau cover. Wiring also needs to be carefully run not to interfere with operation of the cover.
The passenger side piece is:
BED TRIM CORNER RH
Part # PT00032837-D
$89.95
thedocdm
Jon
San Francisco
2016 Tesla Model S P100D, 2023 R1T Adventure
Any idea on range impact with the tent high up?
Hexijen
Caley
Signal Hill, CA
R1T Glacier/Ocean Coast, 20AT, Offroad
Hey yall!
? Products I Used:
Nice build! In your video you mention connecting the light bar to the 12v battery, was wondering if you connected to the primary 12v battery or the secondary, and which post you connected it to (if it matters).
Thanks!
rancur
rancur
Will
Phoenix
www.willcurran.com
Entrepreneur
Thanks!
So I only have one battery. I thought I had two but the second one is a false battery for my newer model. It shouldn’t matter though ◡̈
WattTruckMatt
Austin
2022 Rivian R1T
I believe they replaced the second 12V battery with a capacitor.
ancient
Jason
Sacramento, CA
R1T Quad on 20" Voltiacs w/ Falken Wildpeak AT4W
Doing the damn thing
tough to say because we ended up adding some additional stuff such as awnings shortly after but honestly maybe .2 miles per kilowatt?
Now that’s you’re fully rigged up, what are you averaging per kilowatt?
jiujitsuallen
Allen
Sierra Madre
'23 R1T, '22 Taycan CT4, '20 Defender 110
Hey yall!
? Products I Used:
What are you using to lock your iKamper? I have the same ORR rack but hesitant about putting on the RTT because I don't want it to get stolen.
rancur
rancur
Will
Phoenix
www.willcurran.com
Entrepreneur
So when I’m on the road I’m seeing about 1.5 ◡̈ Before I added everything I was at maybe 1.75-1.8. Not a huge change to affect my behavior.
rancur
rancur
Will
Phoenix
www.willcurran.com
Entrepreneur
I am just using the iKamper hardware that ORR sells. ◡̈ I did put an AirTag in the tent if that were to happen.
